TS grand plan
Lisandro Dalcin
dalcinl at gmail.com
Thu Sep 24 15:05:19 CDT 2009
Jed, I agree that discussing on names is bikesheding... but I really
hate inconsistencies... So I think we should have
#define TSRK "rk"
#define TSCN "cn"
#define TSGL "gl"
or the longish versions (both in the macro name and the macro
value)... I prefer the longish ones, you seems to prefer the shorter
ones... Discussing/advocating on these preferences is bikesheding, and
I'll be fine with either in the end, but inconsistencies between these
related names is something I cannot easily accept.
On Thu, Sep 24, 2009 at 4:47 PM, Jed Brown <jed at 59a2.org> wrote:
> Lisandro Dalcin wrote:
>> On Thu, Sep 24, 2009 at 10:00 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> TSType is the only type that has _ in the middle (SNES, KSP etc etc do
>>> not) therefor the correct fix is to remove the _
>>> from the middle of all TSType names and you can follow all the rules :-)
>>> Barry
>> Agreed... we should change all the TS_<TYPENAME> to TS<TYPENAME> ...
> Done
>> However, I now think that we should have
>> #define TS_GENERAL_LINEAR "general-linear"
>> as we already have "crank-nicholson" and "runge-kutta" ...
> Maybe, but all the other packages tend to use acronyms, cf. "asm", "cg",
> "ls", versus "additive-schwarz", "conjugate-gradients", "line-search".
> It's a bike shed at this point, and I don't care much although I do like
> short names because it requires less typing to experiment on the command
> line.
> Jed
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
