remove 'x11' test from 'make test'
    Boyana Norris
    norris at mcs.anl.gov
    Thu Oct 29 09:14:15 CDT 2009
Thanks for looking that up (I am wondering why it's not default) -- I
did that and hopefully X won't need restarting.
Boyana
Boyana Norris, Computer Scientist, Argonne National Laboratory
norris at mcs.anl.gov, +1.630.252.7908, http://www.mcs.anl.gov/~norris/
On Oct 28, 2009, at 10:09 PM, Barry Smith wrote:
>   Looks like for 10.5 it is
>> defaults write org.x.X11 nolisten_tcp -boolean true
> On Oct 28, 2009, at 9:04 PM, Satish Balay wrote:
>> Perhaps the relavent setting can be toggled with:
>> defaults com.apple.x11 nolisten_tcp -boolean true
>> http://lists.apple.com/archives/x11-users/2005/May/msg00073.html
>> Satish
>> On Wed, 28 Oct 2009, Barry Smith wrote:
>>> On my Mac
>>> bsmith-laptop:~/Src/petsc-dev] barrysmith% echo $DISPLAY
>>> /tmp/launch-r289TD/:0
>>> I don't seem to have a problem with X when I change my IP address.
>>> I carry my
>>> laptop around open it and use X and it pretty much always works.
>>> Barry
>>> On Oct 28, 2009, at 8:02 PM, Satish Balay wrote:
>>>> On Wed, 28 Oct 2009, Boyana Norris wrote:
>>>>> Apart from the idiot reasons, X11 tests can easily fail on an
>>>>> Apple laptop
>>>>> because the X server becomes unusable every time the IP changes,
>>>>> which is
>>>>> fairly frequently. I don't really use X a lot and thus do not
>>>>> restart the
>>>>> server every time I move the laptop, so these tests fail almost
>>>>> all the
>>>>> time
>>>>> (but I've learned to ignore those errors).
>>>> Linux on laptops used to have this problem - but it doesn't exist
>>>> anymore.
>>>> The reason is - x-server is now bound-to/listen-on a unix socket
>>>> [:0]
>>>> - and not a tcp socket [localhost:0] - so hostname change doesn't
>>>> affect it. [from ps:]
>>>> /usr/bin/Xorg :0 -nr -verbose -auth
>>>> /var/run/gdm/auth-for-gdm-l9vnzI/database -nolisten tcp
>>>> Not sure how this can be done on mac/windows..
>>>> Satish
