remove 'x11' test from 'make test'
Barry Smith
bsmith at mcs.anl.gov
Wed Oct 28 22:09:10 CDT 2009
Looks like for 10.5 it is
> defaults write org.x.X11 nolisten_tcp -boolean true
On Oct 28, 2009, at 9:04 PM, Satish Balay wrote:
> Perhaps the relavent setting can be toggled with:
> defaults com.apple.x11 nolisten_tcp -boolean true
> http://lists.apple.com/archives/x11-users/2005/May/msg00073.html
> Satish
> On Wed, 28 Oct 2009, Barry Smith wrote:
>> On my Mac
>> bsmith-laptop:~/Src/petsc-dev] barrysmith% echo $DISPLAY
>> /tmp/launch-r289TD/:0
>> I don't seem to have a problem with X when I change my IP address.
>> I carry my
>> laptop around open it and use X and it pretty much always works.
>> Barry
>> On Oct 28, 2009, at 8:02 PM, Satish Balay wrote:
>>> On Wed, 28 Oct 2009, Boyana Norris wrote:
>>>> Apart from the idiot reasons, X11 tests can easily fail on an
>>>> Apple laptop
>>>> because the X server becomes unusable every time the IP changes,
>>>> which is
>>>> fairly frequently. I don't really use X a lot and thus do not
>>>> restart the
>>>> server every time I move the laptop, so these tests fail almost
>>>> all the
>>>> time
>>>> (but I've learned to ignore those errors).
>>> Linux on laptops used to have this problem - but it doesn't exist
>>> anymore.
>>> The reason is - x-server is now bound-to/listen-on a unix socket [:
>>> 0]
>>> - and not a tcp socket [localhost:0] - so hostname change doesn't
>>> affect it. [from ps:]
>>> /usr/bin/Xorg :0 -nr -verbose -auth
>>> /var/run/gdm/auth-for-gdm-l9vnzI/database -nolisten tcp
>>> Not sure how this can be done on mac/windows..
>>> Satish
