C/F blas/lapack (tying to build in cygwin)
    Satish Balay
    balay at mcs.anl.gov
    Sat Mar 21 13:37:17 CDT 2009
The theory is when fortran compiler exists - f-blas-lapack should
always work.
And when a fortran compiler exists - its name-mangling might not match
the cblas namemangling... [so clblaslapack with fc is disabled]
Satish
On Sat, 21 Mar 2009, Lisandro Dalcin wrote:
> I was trying to build petsc-dev on win32+cygwin using GCC 4. For some
> reason I did not investigate, gfortran failed to build f-blas-lapack,
> then re-ran configure like below. Why you do not let me use a
> c-blas-lapack despite the fact that I have a Fortran compiler?
> $ python config/configure.py --with-cc=gcc --with-fc=gfortran
> --download-c-blas-lapack=1 --with-mpi=0
>              Configuring PETSc to compile on your system
> TESTING: configureLibrary from
> config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:429)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for details):
> Should request f-blas-lapack, not --download-c-blas-lapack=yes since
> you have a fortran compiler?
