Disabling compilation of win32draw.c
    KACVINSKY Tom
    Tom.KACVINSKY at 3ds.com
    Tue Jan 27 15:44:01 CST 2009
All,
I meant to add that the patch Satish sent me a while ago
worked fine.  I had to make one minor correction to the
patched code and then all was well.
Tom
-----Original Message-----
From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Barry Smith
Sent: Tuesday, January 27, 2009 4:40 PM
To: For users of the development version of PETSc
Cc: petsc-dev at lists.mcs.anl.gov
Subject: Re: Disabling compilation of win32draw.c
    Satish,
      Can you make the update to petsc-3.0.0
Use the macro PETSC_USE_WINDOWS_GRAPHICS to turn on the required
compiling.
Then add a config/PETSc/packages/windowsgraphics.py that defines --
with-windows-graphics
(by default on if Windows is there).
    We need to get this fix out there,
    Thanks
     Barry
On Jan 20, 2009, at 4:06 PM, KACVINSKY Tom wrote:
> How do I disable compilation of win32draw.c?  I do not want/need the
> graphics
> stuff on Windows 32 bit.
> Thanks,
> Tom
