Disabling compilation of win32draw.c
    Satish Balay
    balay at mcs.anl.gov
    Fri Jan 30 01:16:42 CST 2009
I've added this to PETSc/Configure.c - as some of the required code is
in here in configureWin32()
Satish
On Tue, 27 Jan 2009, Barry Smith wrote:
>   Satish,
>     Can you make the update to petsc-3.0.0
> Use the macro PETSC_USE_WINDOWS_GRAPHICS to turn on the required compiling.
> Then add a config/PETSc/packages/windowsgraphics.py that defines
> --with-windows-graphics
> (by default on if Windows is there).
>   We need to get this fix out there,
>   Thanks
>    Barry
> On Jan 20, 2009, at 4:06 PM, KACVINSKY Tom wrote:
> > How do I disable compilation of win32draw.c?  I do not want/need the
> > graphics
> > stuff on Windows 32 bit.
> > Thanks,
> > Tom
