[petsc-dev] eliminating a cause of my recent rant and argument with Matt
Satish Balay
balay at mcs.anl.gov
Mon Dec 28 13:35:35 CST 2009
Sorry - misread the message. Pushed a fix now.
Satish
On Mon, 28 Dec 2009, Satish Balay wrote:
> Looks like this change broke my build. download-mpi looks
> ambigeous. If added - perhaps it should be an alias to download-mpich.
> Satish
> asterix:/home/balay/tmp/spetsc>./configure --with-mpi-dir=/home/balay/soft/linux64/mpich2-1.1
> Configuring PETSc to compile on your system
> TESTING: configureLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:687) Please enter value for download-mpi: 0
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> --download-mpi does not exist! Use --download-mpich or --download-openmpi
> On Sun, 27 Dec 2009, Barry Smith wrote:
> > I have pushed changes to petsc-dev and BuildSystem to put a -known- in front
> > of all of these and replace the nonstandard _ in the sizeof ones to - (except
> > for MPI_Comm and MPI_Fint since those are the type names).
> > Make sure you pull both petsc-dev and config/BuildSystem.
> > Barry
> > On Dec 15, 2009, at 3:30 PM, Satish Balay wrote:
> > > Wrt batch mode, the relavent PETSc configure flags are:
> > > '--with-batch=1',
> > > '--with-mpi-shared=0',
> > > '--with-memcmp-ok',
> > > '--sizeof_char=1',
> > > '--sizeof_void_p=4',
> > > '--sizeof_short=2',
> > > '--sizeof_int=4',
> > > '--sizeof_long=4',
> > > '--sizeof_size_t=4',
> > > '--sizeof_long_long=8',
> > > '--sizeof_float=4',
> > > '--sizeof_double=8',
> > > '--bits_per_byte=8',
> > > '--sizeof_MPI_Comm=4',
> > > '--sizeof_MPI_Fint=4',
> > > '--have-mpi-long-double=1',
> > > wrt autoconf - I think these [sizeof stuff] are just shell
> > > variables. The last time I tried doing something equivalnet to
> > > --with-batch - I just set these variables on the command line.
> > > ./configure ac_cv_sizeof_long_int=8 ac_cv_sizeof_int=4
> > > etc.. So perhaps the current sizeof_char type options already mimic
> > > autoconf. But if we are using --known-sizeofint=8 type flags - thats
> > > also fine.
> > > The other odd flags are --with-memcmp-ok and --have-mpi-long-double=1
> > > Satish
> > > On Tue, 15 Dec 2009, Barry Smith wrote:
> > > > I think a root of the miscommunication between Matt and I with regard to
> > > > --with-mpi-shared is that --with is used for TWO different reasons
> > > > 1) --with-mpi=0 --with-x=1 etc are used to indicate we want to turn off/on
> > > > a
> > > > package. In other words they are COMMANDS to BuildSystem
> > > > 2) --with-mpi-shared=1, --with-sizeofint=8 tells BuildSystems FACTS that
> > > > it
> > > > would normally be figured out by BuildSystem. Usually they are provided on
> > > > the
> > > > command line because ./configure cannot run compiled programs (using
> > > > --with-batch for example).
> > > > I suggest we can the syntax for 2) and consistently use --known-mpi-shared
> > > > --known-sizeofint=8 etc everywhere in help and BuildSystem. It makes
> > > > things
> > > > much clearer and can prevent loads of confusion.
> > > > This is likely not compatible with how autoconf does things. Do they have
> > > > a
> > > > similar split and different names? Is there anything we can copy from
> > > > their
> > > > approach? Do we care?
> > > > What do others think?
> > > > Barry
