eliminating a cause of my recent rant and argument with Matt
Kevin.Buckley at ecs.vuw.ac.nz
Tue Dec 15 16:18:10 CST 2009
> I suggest we can the syntax for 2) and consistently use --known-
> mpi-shared --known-sizeofint=8 etc everywhere in help and BuildSystem.
> It makes things much clearer and can prevent loads of confusion.
> This is likely not compatible with how autoconf does things. Do
> they have a similar split and different names? Is there anything we
> can copy from their approach? Do we care?
Would you not consider using a perfectly decent autoconf-like construct
such as, in the MPI case,
--with-known-mpi-shared
given that it is with the knowledge of the shared MPI that you are
building ?
Kevin M. Buckley Room: CO327
School of Engineering and Phone: +64 4 463 5971
Computer Science
Victoria University of Wellington
New Zealand
