[petsc-maint #38919] Re: stupid, stupid, stupid MPI.py
Lisandro Dalcín dalcinl at gmail.com
Mon Dec 14 10:26:30 CST 2009
On Mon, Dec 14, 2009 at 11:23 AM, Matthew Knepley
<petsc-maint at mcs.anl.gov> wrote:
> On Mon, Dec 14, 2009 at 8:21 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Dec 14, 2009, at 8:16 AM, Matthew Knepley wrote:
>>> I strongly disagree with this change. I would like to back it out until
>>> we discuss it. The correct
>>> thing to do is use --with-shared FOR ALL shared library build requests.
>>> Why should MPI be
>>> different? There is absolutely no need to multiply the mechanisms here.
>>   Yes there is. I want to build MPI shared libraries but not PETSc shared
>> libraries.
> Why?
If you build MPI shared but PETSc static, we are still able to use
mpi4py+petsc4py (and stop there, no chance to add slepc4py to the
sum). Using a static PETSc is strongly discouraged, but anyway
possible, provided that MPI is shared.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
