[petsc-maint #38919] Re: stupid, stupid, stupid MPI.py
Barry Smith
bsmith at mcs.anl.gov
Mon Dec 14 13:06:26 CST 2009
Ok, after tracing through the code I finally understand.
If --with-batch is used (which means programs cannot be run so the
shared library check can not be done) then --with-mpi-shared is used
to say if the MPI libraries are shared or not (instead of testing).
The text is MPI.py is TERRIBLE and confusing. First
help.addArgument('MPI', '-with-mpi-
shared=<bool>', nargs.ArgBool(None, None,
'Try to use shared MPI libraries'))
It does not "Try to use shared libraries". It is a flag to indicate
if the libraries are shared or not.
def checkSharedLibrary(self):
'''Check that the libraries for MPI are shared libraries'''
self.executeTest(self.configureMPIEXEC)
try:
self.shared = self.libraries.checkShared('#include <mpi.h>
\n','MPI_Init','MPI_Initialized','MPI_Finalize',checkLink =
self.checkPackageLink,libraries = self.lib, defaultArg = 'with-mpi-
shared', executor = self.mpiexec)
except RuntimeError, e:
if self.framework.argDB['with-shared']:
raise RuntimeError('Shared libraries cannot be built using
MPI provided.\nEither rebuild with --with-shared=0 or rebuild MPI with
shared library support')
self.framework.logPrint('MPI libraries cannot be used with
shared libraries')
self.shared = 0
return
It does not check "that the libraries are shared" it just sets a
flag indicating if they are shared or not.
I will change the docs to make things clear and introduce a --
download-mpich-shared to tell it to make the shared libraries.
Now everyone should be happy,
Will push my fixes shortly.
Barry
On Dec 14, 2009, at 10:40 AM, Matthew Knepley wrote:
> On Mon, Dec 14, 2009 at 10:39 AM, Lisandro Dalcín
> <dalcinl at gmail.com> wrote:
> On Mon, Dec 14, 2009 at 1:33 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Mon, Dec 14, 2009 at 10:28 AM, Lisandro Dalcín
> >> On Mon, Dec 14, 2009 at 11:34 AM, Matthew Knepley <knepley at gmail.com
> >> wrote:
> >> > If we are using shared libraries, and the MPI shared library
> was broken,
> >> > the
> >> > configure failed. This option was added
> >> > to allow the user to turn off that check.
> >> What does 'broken' means? How can the lib be broken for
> configure, but
> >> not for linking PETSc or user programs?
> > It would also be broken there too, and fall back to the static
> libraries.
> Sorry, I'm still confused. What does 'broken' means? Sorry about my
> ignorance: In the case of a corrupted (whatever that could mean)
> shared lib file, does the linker fall back to use a static lib?
> I believe so. I know that is why I put this in. The shared lib test
> would break, since
> they were not functional, but the library overall would work.
> Matt
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
