eliminating a cause of my recent rant and argument with Matt
Tue Dec 15 15:14:18 CST 2009
    I think a root of the miscommunication between Matt and I with
regard to --with-mpi-shared is that --with is used for TWO different
reasons
1) --with-mpi=0 --with-x=1 etc are used to indicate we want to turn
off/on a package. In other words they are COMMANDS to BuildSystem
2) --with-mpi-shared=1, --with-sizeofint=8 tells BuildSystems FACTS
that it would normally be figured out by BuildSystem. Usually they are
provided on the command line because ./configure cannot run compiled
programs (using --with-batch for example).
    I suggest we can the syntax for 2) and consistently use --known-
mpi-shared --known-sizeofint=8 etc everywhere in help and BuildSystem.
It makes things much clearer and can prevent loads of confusion.
    This is likely not compatible with how autoconf does things. Do
they have a similar split and different names? Is there anything we
can copy from their approach? Do we care?
    What do others think?
    Barry
