[petsc-maint #38919] Re: stupid, stupid, stupid MPI.py
    Matthew Knepley
    petsc-maint at mcs.anl.gov
    Mon Dec 14 08:23:23 CST 2009
On Mon, Dec 14, 2009 at 8:21 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Dec 14, 2009, at 8:16 AM, Matthew Knepley wrote:
>  I strongly disagree with this change. I would like to back it out until we
>> discuss it. The correct
>> thing to do is use --with-shared FOR ALL shared library build requests.
>> Why should MPI be
>> different? There is absolutely no need to multiply the mechanisms here.
>   Yes there is. I want to build MPI shared libraries but not PETSc shared
> libraries.
Why?
  Matt
>   Barry
>> This is blowing up a small documentation problem into a big design flaw.
>>   Matt
>> On Mon, Dec 14, 2009 at 8:14 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   This is the help message that has always been there
>>   help.addArgument('MPI', '-with-mpi-shared=<bool>',
>>     nargs.ArgBool(None, None, 'Try to use shared MPI libraries'))
>>  Note the word   TRY! How can you TRY to use shared MPI libraries if you
>> don't build the shared MPI libraries. TRY means make some effort, if you
>> don't make the MPI libraries with shared then your are not trying!
>>  Feel free to add a new option --with-mpi-shared-test if you want, for
>> your weird case; where you want to use shared libraries but don't want to
>> build them.
>>  Barry
>> On Dec 13, 2009, at 10:19 PM, Matthew Knepley wrote:
>> On Sun, Dec 13, 2009 at 9:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  So if I pass --with-mpi-shared into MPI.py it TESTS if the MPI libraries
>> are shared. Fine. But if it is download-mpich IT DOES NOT try to make
>> shared
>> libraries for MPICH. It only tries to make shared libraries for MPI if
>> --with-shared is passed. WTF?
>> --with-mpi-shared is a workaround option. Perhaps it should be renamed. It
>> was only put in to avoid the shared library test.
>>  So I change it so that it tries to make mpi shared libraries if
>> --with-mpi-shared is passed but not also --with-shared. What happens?
>> "Configuring with shared libraries - but the system/compilers do not
>> support this." How the hell does it know the system/compilers do not
>> support
>> this? So I have to change the code to not reject the --with-mpi-shared
>> when
>> using static libraries.
>> Wait, don't make that change. --with-mpi-shared should NOT control
>> anything
>> but the test.
>>  Sometimes I just want to delete the whole stinking repository of crud
>> piled on crap piled on crud. Maybe we need to start having code reviews
>> instead of shoving random code into random files and hope that sometimes
>> things might work.
>>  Ok, well I shoved some random code in and got it to behave reasonably for
>> me, until tomorrow,
>>  Barry
>> This problem caused my early problem, since it ignored the
>> --with-mpi-shared option it did not think it needed to rebuild mpich.
>> I do not understand this. Can we rollback this change and discuss it?
>>  Matt
>> experiments
>> is infinitely more interesting than any results to which their experiments
>> lead.
>> -- Norbert Wiener
>> are shared. Fine. But if it is download-mpich IT DOES NOT try to make shared
>> support this." How the hell does it know the system/compilers do not support
>> this? So I have to change the code to not reject the --with-mpi-shared when
>> anything but the test.
>> things might work.
>> me, until tomorrow,
>>  Barry
>>  Matt
>> experiments lead.
>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091214/527dcdc2/attachment.html>
