[petsc-maint #38919] Re: stupid, stupid, stupid MPI.py
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Dec 14 08:28:47 CST 2009
On Dec 14, 2009, at 8:23 AM, Matthew Knepley wrote:
> On Mon, Dec 14, 2009 at 8:21 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>> On Dec 14, 2009, at 8:16 AM, Matthew Knepley wrote:
>> I strongly disagree with this change. I would like to back it out
>> until we
>>> discuss it. The correct
>>> thing to do is use --with-shared FOR ALL shared library build
>>> requests.
>>> Why should MPI be
>>> different? There is absolutely no need to multiply the mechanisms
>>> here.
>>  Yes there is. I want to build MPI shared libraries but not PETSc
>> shared
>> libraries.
> Why?
     It doesn't matter why I want to do it.
     Why the heck does --with-mpi-shared exist if it isn't used to
control MPI shared libraries, should we remove it?
     Barry
>  Matt
>>  Barry
>>> This is blowing up a small documentation problem into a big design
>>> flaw.
>>>  Matt
>>> On Mon, Dec 14, 2009 at 8:14 AM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>>  This is the help message that has always been there
>>>  help.addArgument('MPI', '-with-mpi-shared=<bool>',
>>>    nargs.ArgBool(None, None, 'Try to use shared MPI libraries'))
>>> Note the word   TRY! How can you TRY to use shared MPI libraries
>>> if you
>>> don't build the shared MPI libraries. TRY means make some effort,
>>> if you
>>> don't make the MPI libraries with shared then your are not trying!
>>> Feel free to add a new option --with-mpi-shared-test if you want,
>>> for
>>> your weird case; where you want to use shared libraries but don't
>>> want to
>>> build them.
>>> Barry
>>> On Dec 13, 2009, at 10:19 PM, Matthew Knepley wrote:
>>> On Sun, Dec 13, 2009 at 9:36 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>> So if I pass --with-mpi-shared into MPI.py it TESTS if the MPI
>>> libraries
>>> are shared. Fine. But if it is download-mpich IT DOES NOT try to
>>> make
>>> shared
>>> libraries for MPICH. It only tries to make shared libraries for
>>> MPI if
>>> --with-shared is passed. WTF?
>>> --with-mpi-shared is a workaround option. Perhaps it should be
>>> renamed. It
>>> was only put in to avoid the shared library test.
>>> So I change it so that it tries to make mpi shared libraries if
>>> --with-mpi-shared is passed but not also --with-shared. What
>>> happens?
>>> "Configuring with shared libraries - but the system/compilers do not
>>> support this." How the hell does it know the system/compilers do not
>>> support
>>> this? So I have to change the code to not reject the --with-mpi-
>>> shared
>>> when
>>> using static libraries.
>>> Wait, don't make that change. --with-mpi-shared should NOT control
>>> anything
>>> but the test.
>>> Sometimes I just want to delete the whole stinking repository of
>>> crud
>>> piled on crap piled on crud. Maybe we need to start having code
>>> reviews
>>> instead of shoving random code into random files and hope that
>>> sometimes
>>> things might work.
>>> Ok, well I shoved some random code in and got it to behave
>>> reasonably for
>>> me, until tomorrow,
>>> Barry
>>> This problem caused my early problem, since it ignored the
>>> --with-mpi-shared option it did not think it needed to rebuild
>>> mpich.
>>> I do not understand this. Can we rollback this change and discuss
>>> it?
>>> Matt
>>> What most experimenters take for granted before they begin their
>>> experiments
>>> is infinitely more interesting than any results to which their
>>> experiments
>>> lead.
>>> -- Norbert Wiener
>>> libraries
>>> make shared
>>> MPI if
>>> renamed. It
>>> happens?
>>> not support
>>> shared when
>>> anything but the test.
>>> crud
>>> reviews
>>> sometimes
>>> things might work.
>>> reasonably for
>>> me, until tomorrow,
>>> Barry
>>> mpich.
>>> it?
>>> Matt
>>> experiments is infinitely more interesting than any results to
>>> which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> which their
>>> experiments lead.
>>> -- Norbert Wiener
> experiments
> experiments
> lead.
> -- Norbert Wiener
> until we discuss it. The correct
> requests. Why should MPI be
> here.
> shared libraries.
> Why?
>   Matt
>   Barry
> flaw.
>   Matt
> shared=<bool>',                           nargs.ArgBool(None, None,
>  Note the word   TRY! How can you TRY to use shared MPI libraries if
> you don't build the shared MPI libraries. TRY means make some
> effort, if you don't make the MPI libraries with shared then your
> are not trying!
> for your weird case; where you want to use shared libraries but
> don't want to build them.
>  Barry
> libraries
> make shared
> libraries for MPICH. It only tries to make shared libraries for MPI if
> renamed. It
> --with-mpi-shared is passed but not also --with-shared. What happens?
> support
> shared when
> anything
> but the test.
>  Sometimes I just want to delete the whole stinking repository of crud
> reviews
> sometimes
> things might work.
> reasonably for
> me, until tomorrow,
>  Barry
> --with-mpi-shared option it did not think it needed to rebuild mpich.
> I do not understand this. Can we rollback this change and discuss it?
>  Matt
> experiments
> experiments
> lead.
> -- Norbert Wiener
> libraries are shared. Fine. But if it is download-mpich IT DOES NOT
> try to make shared libraries for MPICH. It only tries to make shared
> libraries for MPI if --with-shared is passed. WTF?
> renamed. It was only put in to avoid the shared library test.
>  So I change it so that it tries to make mpi shared libraries if --
> support this? So I have to change the code to not reject the --with-
> mpi-shared when using static libraries.
> crud piled on crap piled on crud. Maybe we need to start having code
> reviews instead of shoving random code into random files and hope
> that sometimes things might work.
> reasonably for me, until tomorrow,
>  Barry
> This problem caused my early problem, since it ignored the --with-
>  Matt
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
> -- Norbert Wiener
