[petsc-maint #38919] Re: stupid, stupid, stupid MPI.py
Barry Smith
bsmith at mcs.anl.gov
Mon Dec 14 08:21:49 CST 2009
On Dec 14, 2009, at 8:16 AM, Matthew Knepley wrote:
> I strongly disagree with this change. I would like to back it out
> until we discuss it. The correct
> thing to do is use --with-shared FOR ALL shared library build
> requests. Why should MPI be
> different? There is absolutely no need to multiply the mechanisms
> here.
Yes there is. I want to build MPI shared libraries but not PETSc
shared libraries.
Barry
> This is blowing up a small documentation problem into a big design
> flaw.
> Matt
> On Mon, Dec 14, 2009 at 8:14 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> This is the help message that has always been there
> help.addArgument('MPI', '-with-mpi-
> shared=<bool>', nargs.ArgBool(None, None,
> 'Try to use shared MPI libraries'))
> Note the word TRY! How can you TRY to use shared MPI libraries
> if you don't build the shared MPI libraries. TRY means make some
> effort, if you don't make the MPI libraries with shared then your
> are not trying!
> Feel free to add a new option --with-mpi-shared-test if you want,
> for your weird case; where you want to use shared libraries but
> don't want to build them.
> Barry
> On Dec 13, 2009, at 10:19 PM, Matthew Knepley wrote:
> On Sun, Dec 13, 2009 at 9:36 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> So if I pass --with-mpi-shared into MPI.py it TESTS if the MPI
> libraries
> are shared. Fine. But if it is download-mpich IT DOES NOT try to
> make shared
> libraries for MPICH. It only tries to make shared libraries for MPI if
> --with-shared is passed. WTF?
> --with-mpi-shared is a workaround option. Perhaps it should be
> renamed. It
> was only put in to avoid the shared library test.
> So I change it so that it tries to make mpi shared libraries if
> --with-mpi-shared is passed but not also --with-shared. What happens?
> "Configuring with shared libraries - but the system/compilers do not
> support this." How the hell does it know the system/compilers do not
> support
> this? So I have to change the code to not reject the --with-mpi-
> shared when
> using static libraries.
> Wait, don't make that change. --with-mpi-shared should NOT control
> anything
> but the test.
> Sometimes I just want to delete the whole stinking repository of crud
> piled on crap piled on crud. Maybe we need to start having code
> reviews
> instead of shoving random code into random files and hope that
> sometimes
> things might work.
> Ok, well I shoved some random code in and got it to behave
> reasonably for
> me, until tomorrow,
> Barry
> This problem caused my early problem, since it ignored the
> --with-mpi-shared option it did not think it needed to rebuild mpich.
> I do not understand this. Can we rollback this change and discuss it?
> Matt
> experiments
> is infinitely more interesting than any results to which their
> experiments
> lead.
> -- Norbert Wiener
> libraries are shared. Fine. But if it is download-mpich IT DOES NOT
> try to make shared libraries for MPICH. It only tries to make shared
> libraries for MPI if --with-shared is passed. WTF?
> renamed. It was only put in to avoid the shared library test.
> So I change it so that it tries to make mpi shared libraries if --
> support this? So I have to change the code to not reject the --with-
> mpi-shared when using static libraries.
> anything but the test.
> crud piled on crap piled on crud. Maybe we need to start having code
> reviews instead of shoving random code into random files and hope
> that sometimes things might work.
> reasonably for me, until tomorrow,
> Barry
> This problem caused my early problem, since it ignored the --with-
> Matt
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
