This code in BuildSystem makes NO fucking sense
Barry Smith
bsmith at mcs.anl.gov
Wed Dec 9 18:33:18 CST 2009
On Dec 9, 2009, at 6:29 PM, Matthew Knepley wrote:
> On Wed, Dec 9, 2009 at 6:24 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> in compilers.py it logs and error message but keeps on running if
> the C libraries cannot be used from Fortran. Why is this? It seems
> totally insane, it just delays the error until later when it is
> confusing and unclear what the problem is. Is there a DAMN good
> reason I shouldn't fix this?
> I believe we did this because
> 1) PETSc itself does not require it. We do all the linking with C
LIE, LIE, LIE!!!! The very test for Fortran name mangling uses
gfortran to link!!!!! Thus Fortran name mangling test will ALWAYS fail
if the C libraries fail. HENCE PETSc does require C libraries work
from Fortran. So you need to either
1) generate a true error here. or
2) change the Fortran mangle test to not link with FC
I vote for 1
Barry
> 2) Some Fortran linkers refused to handle the C libraries and we
> had not work around
> By failing, we would have prevented some user from enjoying his
> perversely isolationist
> Fortran compiler.
> Matt
> Barry
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
