This code in BuildSystem makes NO fucking sense
Wed Dec 9 18:29:17 CST 2009
On Wed, Dec 9, 2009 at 6:24 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> in compilers.py it logs and error message but keeps on running if the C
> libraries cannot be used from Fortran. Why is this? It seems totally insane,
> it just delays the error until later when it is confusing and unclear what
> the problem is. Is there a DAMN good reason I shouldn't fix this?
I believe we did this because
  1) PETSc itself does not require it. We do all the linking with C
  2) Some Fortran linkers refused to handle the C libraries and we had not
work around
By failing, we would have prevented some user from enjoying his perversely
isolationist
Fortran compiler.
  Matt
>   Barry
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091209/d0367c41/attachment.html>
