This code in BuildSystem makes NO fucking sense
Wed Dec 9 18:34:45 CST 2009
On Wed, Dec 9, 2009 at 6:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Dec 9, 2009, at 6:29 PM, Matthew Knepley wrote:
>  On Wed, Dec 9, 2009 at 6:24 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> in compilers.py it logs and error message but keeps on running if the C
>> libraries cannot be used from Fortran. Why is this? It seems totally insane,
>> it just delays the error until later when it is confusing and unclear what
>> the problem is. Is there a DAMN good reason I shouldn't fix this?
>> I believe we did this because
>>  1) PETSc itself does not require it. We do all the linking with C
>  LIE, LIE, LIE!!!!    The very test for Fortran name mangling uses gfortran
> to link!!!!! Thus Fortran name mangling test will ALWAYS fail if the C
> libraries fail. HENCE PETSc does require C libraries work from Fortran. So
> you need to either
> 1) generate a true error here. or
> 2) change the Fortran mangle test to not link with FC
> I vote for 1
2) is not possible (AFAIK) so it has to be 1. I will make it an error.
  Matt
>   Barry
>>  2) Some Fortran linkers refused to handle the C libraries and we had not
>> work around
>> By failing, we would have prevented some user from enjoying his perversely
>> isolationist
>> Fortran compiler.
>>  Matt
>>  Barry
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20091209/488e1dd7/attachment.html>
