USFFT Mat class
Dmitry Karpeev
karpeev at mcs.anl.gov
Wed Oct 8 14:30:44 CDT 2008
Well, USFFT will be a separate class, independent of FFTW.
I can register USFFT and leave FFTW unregistered.
Also, from what I understand, MatSetType will also fail with FFTW
as it is right now?
Dmitry.
On Wed, Oct 8, 2008 at 2:27 PM, Matthew Knepley <knepley at gmail.com> wrote:
> This means that you cannot use -mat_type fftw. Probably because no
> combination
> of options can currently initialize it correctly. It is fine to leave
> out USFFT until this
> is possible.
> Matt
> On Wed, Oct 8, 2008 at 2:20 PM, Dmitry Karpeev <karpeev at mcs.anl.gov>
> wrote:
> > I'm writing a new Seq matrix class called USFFT that effects the FFT of
> > unevenly-spaced functions.
> > USFFT is roughly, an extension of the SeqFFTW class.
> > While looking at the FFTW Mat class with Satish we noticed that
> > MatCreate_SeqFFTW
> > is not being registered in MatRegisterAll. In light of this, there are
> two
> > question:
> > 1) Is that a problem?
> > 2) Should I register the constructor for the new class
> (MatCreate_SeqUSFFT)?
> > Thanks.
> > Dmitry.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20081008/0927e559/attachment.html>
