changes to petsc-dev may require you to update your source, previously Re: How come it is PetscEvent but all the routines that act on it are PetscLogEventXXXX()?
Barry Smith
bsmith at mcs.anl.gov
Fri May 9 23:30:07 CDT 2008
I have made the following changes to Petsc-dev that may require you
to update your source code:
<ul>
<li>The int stage used in the PetscLogStageXXX() routines is
now a PetscLogStage</li>
<li>PetscEvent is now PetscLogEvent</li>
<li>PetscLogEventRegister() and PetscLogStageRegister() now
return the result in the final argument instead of the first</li>
<li>PetscLogClassRegister() is changed to
PetscCookieRegister() and returns the cookie in the final argument,
not the first</li>
</ul>
Please let petsc-maint know immediately if you find a problem, and
feel free to curse me out for the changes
Barry
I realized that I was the one who made the initial mistake. I
introduced PetscEvent because I did not like the int that make
was using for events. I should have, at that time, introduced
PetscLogEvent, not PetscEvent. I also didn't fix the stage like I
should have.
On May 7, 2008, at 10:48 AM, Richard Tran Mills wrote:
> Barry,
> I like the the suggestion to change PetscLogEvent* to PetscEvent*,
> but to be consistent with naming then I think we would also need to
> change PetscLogStage* to PetscStage*, etc.
> Just my 0.5 cents.
> --Richard
> Barry Smith wrote:
>> On May 5, 2008, at 7:39 PM, Matthew Knepley wrote:
>>> Actually, I would argue that these methods do not actually act on
>>> PetscEvent
>>> at all (which is just an integer), but rather on a PetscLog. That
>>> is why I named
>>> them that way.
>> The namage has to be consistent with any normal Joe's thinking
>> about the usage,
>> not based on some implementation issue that only you know about.
>> Names are for
>> users, not for the guru developers. Guru developers could name
>> their variables and
>> functions a1 to a2303 and have no problem maintaining the code.
>> I think the macro names should be changed to PetscEventBegin.... not
>> PetscLogEventBegin.... based on the policy in PETSc that "methods"
>> on "objects"
>> start with the name of the objects: e.g. MatMult(Mat,....) The user
>> shouldn't know
>> or care that PetscEvent is an int and not a PetscEvent or
>> PetscLogEvent object.
>> Barry
>> We could instead change PetscEvent to PetscLogEvent but I think
>> PetscEvent
>> is clear enough without the Log in it.
>>> Matt
>>> On Sat, May 3, 2008 at 6:26 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>>> Doesn't seem right.
>>>> Barry
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
> Richard Tran Mills, Ph.D. | E-mail: rmills at climate.ornl.gov
> Computational Scientist | Phone: (865) 241-3198
> Computational Earth Sciences Group | Fax: (865) 574-0405
> Oak Ridge National Laboratory | http://climate.ornl.gov/~rmills
