How come it is PetscEvent but all the routines that act on it are PetscLogEventXXXX()?
    Barry Smith
    bsmith at mcs.anl.gov
    Wed May  7 11:31:15 CDT 2008
On May 7, 2008, at 10:48 AM, Richard Tran Mills wrote:
> Barry,
> I like the the suggestion to change PetscLogEvent* to PetscEvent*,
> but to be consistent with naming then I think we would also need to
> change PetscLogStage* to PetscStage*, etc.
     I don't use that too much so I haven't thought about it. But
"stage" is an int not a PetscStage so my rule about
method names and objects doesn't apply.  It appears "stage" should
become a PetscStage and then the Log would be
dropped from PetscLogStage ....
   Barry
> Just my 0.5 cents.
> --Richard
> Barry Smith wrote:
>> On May 5, 2008, at 7:39 PM, Matthew Knepley wrote:
>>> Actually, I would argue that these methods do not actually act on
>>> PetscEvent
>>> at all (which is just an integer), but rather on a PetscLog. That
>>> is why I named
>>> them that way.
>>   The namage has to be consistent with any normal Joe's thinking
>> about the usage,
>> not based on some implementation issue that only you know about.
>> Names are for
>> users, not for the guru developers. Guru developers could name
>> their variables and
>> functions a1 to a2303 and have no problem maintaining the code.
>>  I think the macro names should be changed to PetscEventBegin.... not
>> PetscLogEventBegin.... based on the policy in PETSc that "methods"
>> on "objects"
>> start with the name of the objects: e.g. MatMult(Mat,....) The user
>> shouldn't know
>> or care that PetscEvent is an int and not a PetscEvent or
>> PetscLogEvent object.
>>   Barry
>> We could instead change PetscEvent to PetscLogEvent but I think
>> PetscEvent
>> is clear enough without the Log in it.
>>> Matt
>>> On Sat, May 3, 2008 at 6:26 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>>>  Doesn't seem right.
>>>>  Barry
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
> Richard Tran Mills, Ph.D.            |   E-mail: rmills at climate.ornl.gov
> Computational Scientist              |   Phone:  (865) 241-3198
> Computational Earth Sciences Group   |   Fax:    (865) 574-0405
> Oak Ridge National Laboratory        |   http://climate.ornl.gov/~rmills
