petscvariables: hardwired build dir instead of install dir
Barry Smith
bsmith at mcs.anl.gov
Mon Mar 24 22:53:32 CDT 2008
On Mar 24, 2008, at 10:42 PM, Matthew Knepley wrote:
> On Mon, Mar 24, 2008 at 10:38 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>> On Mar 24, 2008, at 10:25 PM, Matthew Knepley wrote:
>>> On Mon, Mar 24, 2008 at 10:14 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>>> Matt,
>>>> The sed is so trivial it is silly to even think about replacing
>>>> it with python! I did not realize until after reading Lisandro's
>>>> email
>>> What does that have to do with anything? If its so trivial, then it
>>> won't
>>> take any time at all. This is at least the third time I have had to
>>> fool
>>> with this sed stuff (I already reported that sed bug two months
>>> ago).
>>> I do not want to do it again. Is there any justification, except
>>> inertia,
>>> for keeping that in sed?
>> Not having hundreds of dinky little python scripts lying around
>> that do the same thing as Unix utilities is a good reason.
>> If you write the entire "install:" rule in python that would be
>> great,
>> then you could start on some of the other rules in conf/rules
>> I am only objecting to replacing Unix one-liners with python one
>> liners.
> Fine, but you just asked for a lot more Python then 1 line to check
> which form of
> the -i flag is on the machine.
Yes, but that is the autoconf model! You wanted the autoconf
model, not me!
You first tried it with autoconf, not possible, so you wrote a better
than autoconf
in python. I never asked anyone to make a conf system, I was perfectly
happy
requiring people to write the correct flags directly into
petscconf :-). What bothers
me about one-line python scripts to fix Unix weirdness is now you have
two
models (some things you fix by running config/configure.py and
figuring things
out and some things you fix by replacing Unix with python). One thing
you
should know about me is I HATE HATE HATE HATE using two models for
doing something at the
same time (this is why I hate Mathematica and PERL, they each support
about
20 different programming models that can be used together). So now we
have
reached the root if the issue; in my mind if you introduce a new model
approach to
solving some problem you toss the old, you don't use them both together!
Barry
> Matt
>> Barry
>>> Matt
>>>> that the sed -i option behaved differently on different systems.
>>>> Barry
>>>> On Mar 24, 2008, at 10:07 PM, Matthew Knepley wrote:
>>>>> On Mon, Mar 24, 2008 at 9:50 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>>> On Mar 24, 2008, at 10:57 AM, Lisandro Dalcin wrote:
>>>>>>> Barry, things are still broken. I think that at some point we
>>>>>>> have
>>>>>>> to
>>>>>>> review the 'install:' target more carefully.
>>>>>>> First, the 'sed' command i being called in a wrong way.
>>>>>> This is not true; the sed is being called correctly. The problem
>>>>>> is that -i
>>>>>> is not a standard sed option and different systems gnu and
>>>>>> freebsd
>>>>>> treat
>>>>>> it differently. freebsd requires a space between the -i and the
>>>>>> suffix;
>>>>>> gnu has no space; gnu also allows the use of -i to indicate no
>>>>>> backup
>>>>>> while freebsd expects -i ""
>>>>>> Your patch works on POS gnu systems, but is broken on far
>>>>>> superior
>>>>>> Apple MacOS X systems! :-)
>>>>>> Matt you need to add a config/configure.py test to detect the
>>>>>> type of sed -i it is.
>>>>> I totally disagree. We should ditch all this crap, and just write
>>>>> nice, PORTABLE
>>>>> Python code. I will do it. I just need someone to explain what
>>>>> this
>>>>> sed is doing.
>>>>> Matt
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to
>>>>> which
>>>>> their experiments lead.
>>>>> -- Norbert Wiener
>>> experiments is infinitely more interesting than any results to which
>>> -- Norbert Wiener
> -- Norbert Wiener
