petscvariables: hardwired build dir instead of install dir
Mon Mar 24 23:26:39 CDT 2008
On Mon, Mar 24, 2008 at 10:53 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  On Mar 24, 2008, at 10:42 PM, Matthew Knepley wrote:
>  > On Mon, Mar 24, 2008 at 10:38 PM, Barry Smith <bsmith at mcs.anl.gov>
>  > wrote:
>  >> On Mar 24, 2008, at 10:25 PM, Matthew Knepley wrote:
>  >>> On Mon, Mar 24, 2008 at 10:14 PM, Barry Smith <bsmith at mcs.anl.gov>
>  >>> wrote:
>  >>>>   Matt,
>  >>>>    The sed is so trivial it is silly to even think about replacing
>  >>>> it with python!  I did not realize until after reading Lisandro's
>  >>>> email
>  >>> What does that have to do with anything? If its so trivial, then it
>  >>> won't
>  >>> take any time at all. This is at least the third time I have had to
>  >>> fool
>  >>> with this sed stuff (I already reported that sed bug two months
>  >>> ago).
>  >>> I do not want to do it again. Is there any justification, except
>  >>> inertia,
>  >>> for keeping that in sed?
>  >>    Not having hundreds of dinky little python scripts lying around
>  >> that do the same thing as Unix utilities is a good reason.
>  >>   If you write the entire "install:" rule in python that would be
>  >> great,
>  >> then you could start on some of the other rules in conf/rules
>  >> I am only objecting to replacing Unix one-liners with python one
>  >> liners.
>  > Fine, but you just asked for a lot more Python then 1 line to check
>  > which form of
>  > the -i flag is on the machine.
>     Yes, but that is the autoconf model! You wanted the autoconf
>  model, not me!
>  You first tried it with autoconf, not possible, so you wrote a better
>  than autoconf
>  in python. I never asked anyone to make a conf system, I was perfectly
>  happy
>  requiring people to write the correct flags directly into
>  petscconf :-). What bothers
>  me about one-line python scripts to fix Unix weirdness is now you have
>  two
>  models (some things you fix by running config/configure.py and
>  figuring things
>  out and some things you fix by replacing Unix with python). One thing
>  you
>  should know about me is I HATE HATE HATE HATE using two models for
>  doing something at the
>  same time (this is why I hate Mathematica and PERL, they each support
>  about
>  20 different programming models that can be used together). So now we
>  have
>  reached the root if the issue; in my mind if you introduce a new model
>  approach to
>  solving some problem you toss the old, you don't use them both together!
I am all for consistency. However I have a different interpretation of
what constitutes
the model. I thought the model was
  1) Test a set of tools, e.g. compilers, make, ...
  2) Customize the use of each based upon our tests
  3) Use the set of tools required for each build task
I think I am proposing a decision for 3), namely replacing one tool
with another. We
already do this, for instance when we link with a linker or a
compiler. I think we should
eliminate all uses of sed with python. Notice that this is not wasted
work, as it will
survive when eventually everything is replaced by Python.
   Matt
>     Barry
>  >   Matt
>  >>    Barry
>  >>> Matt
>  >>>> that the sed -i option behaved differently on different systems.
>  >>>>   Barry
>  >>>> On Mar 24, 2008, at 10:07 PM, Matthew Knepley wrote:
>  >>>>> On Mon, Mar 24, 2008 at 9:50 PM, Barry Smith <bsmith at mcs.anl.gov>
>  >>>>> wrote:
>  >>>>>> On Mar 24, 2008, at 10:57 AM, Lisandro Dalcin wrote:
>  >>>>>>> Barry, things are still broken. I think that at some point we
>  >>>>>>> have
>  >>>>>>> to
>  >>>>>>> review the 'install:' target  more carefully.
>  >>>>>>> First, the 'sed' command i being called in a wrong way.
>  >>>>>>  This is not true; the sed is being called correctly. The problem
>  >>>>>> is that -i
>  >>>>>> is not a standard sed option and different systems gnu and
>  >>>>>> freebsd
>  >>>>>> treat
>  >>>>>> it differently. freebsd requires a space between the -i and the
>  >>>>>> suffix;
>  >>>>>> gnu has no space; gnu also allows the use of -i to indicate no
>  >>>>>> backup
>  >>>>>> while freebsd expects -i ""
>  >>>>>> Your patch works on POS gnu systems, but is broken on far
>  >>>>>> superior
>  >>>>>> Apple MacOS X systems! :-)
>  >>>>>>  Matt you need to add a config/configure.py test to detect the
>  >>>>>> type of sed -i it is.
>  >>>>> I totally disagree. We should ditch all this crap, and just write
>  >>>>> nice, PORTABLE
>  >>>>> Python code. I will do it. I just need someone to explain what
>  >>>>> this
>  >>>>> sed is doing.
>  >>>>> Matt
>  >>>>> What most experimenters take for granted before they begin their
>  >>>>> experiments is infinitely more interesting than any results to
>  >>>>> which
>  >>>>> their experiments lead.
>  >>>>> -- Norbert Wiener
>  >>> experiments is infinitely more interesting than any results to which
>  >>> -- Norbert Wiener
>  > -- Norbert Wiener
-- Norbert Wiener
