petscvariables: hardwired build dir instead of install dir
    Matthew Knepley
    knepley at gmail.com
    Mon Mar 24 22:42:49 CDT 2008
On Mon, Mar 24, 2008 at 10:38 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  On Mar 24, 2008, at 10:25 PM, Matthew Knepley wrote:
>  > On Mon, Mar 24, 2008 at 10:14 PM, Barry Smith <bsmith at mcs.anl.gov>
>  > wrote:
>  >>    Matt,
>  >>     The sed is so trivial it is silly to even think about replacing
>  >> it with python!  I did not realize until after reading Lisandro's
>  >> email
>  > What does that have to do with anything? If its so trivial, then it
>  > won't
>  > take any time at all. This is at least the third time I have had to
>  > fool
>  > with this sed stuff (I already reported that sed bug two months ago).
>  > I do not want to do it again. Is there any justification, except
>  > inertia,
>  > for keeping that in sed?
>     Not having hundreds of dinky little python scripts lying around
>  that do the same thing as Unix utilities is a good reason.
>    If you write the entire "install:" rule in python that would be
>  great,
>  then you could start on some of the other rules in conf/rules
>  I am only objecting to replacing Unix one-liners with python one liners.
Fine, but you just asked for a lot more Python then 1 line to check
which form of
the -i flag is on the machine.
   Matt
>     Barry
>  >  Matt
>  >> that the sed -i option behaved differently on different systems.
>  >>    Barry
>  >> On Mar 24, 2008, at 10:07 PM, Matthew Knepley wrote:
>  >>> On Mon, Mar 24, 2008 at 9:50 PM, Barry Smith <bsmith at mcs.anl.gov>
>  >>> wrote:
>  >>>> On Mar 24, 2008, at 10:57 AM, Lisandro Dalcin wrote:
>  >>>>> Barry, things are still broken. I think that at some point we have
>  >>>>> to
>  >>>>> review the 'install:' target  more carefully.
>  >>>>> First, the 'sed' command i being called in a wrong way.
>  >>>>   This is not true; the sed is being called correctly. The problem
>  >>>> is that -i
>  >>>> is not a standard sed option and different systems gnu and freebsd
>  >>>> treat
>  >>>> it differently. freebsd requires a space between the -i and the
>  >>>> suffix;
>  >>>> gnu has no space; gnu also allows the use of -i to indicate no
>  >>>> backup
>  >>>> while freebsd expects -i ""
>  >>>>  Your patch works on POS gnu systems, but is broken on far superior
>  >>>> Apple MacOS X systems! :-)
>  >>>>   Matt you need to add a config/configure.py test to detect the
>  >>>> type of sed -i it is.
>  >>> I totally disagree. We should ditch all this crap, and just write
>  >>> nice, PORTABLE
>  >>> Python code. I will do it. I just need someone to explain what this
>  >>> sed is doing.
>  >>>  Matt
>  >>> What most experimenters take for granted before they begin their
>  >>> experiments is infinitely more interesting than any results to which
>  >>> their experiments lead.
>  >>> -- Norbert Wiener
>  > -- Norbert Wiener
-- Norbert Wiener
