petscvariables: hardwired build dir instead of install dir
Mon Mar 24 22:38:35 CDT 2008
On Mar 24, 2008, at 10:25 PM, Matthew Knepley wrote:
> On Mon, Mar 24, 2008 at 10:14 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>>    Matt,
>>     The sed is so trivial it is silly to even think about replacing
>> it with python!  I did not realize until after reading Lisandro's
>> email
> What does that have to do with anything? If its so trivial, then it
> won't
> take any time at all. This is at least the third time I have had to
> fool
> with this sed stuff (I already reported that sed bug two months ago).
> I do not want to do it again. Is there any justification, except
> inertia,
> for keeping that in sed?
    Not having hundreds of dinky little python scripts lying around
that do the same thing as Unix utilities is a good reason.
   If you write the entire "install:" rule in python that would be
great,
then you could start on some of the other rules in conf/rules
I am only objecting to replacing Unix one-liners with python one liners.
    Barry
>  Matt
>> that the sed -i option behaved differently on different systems.
>>    Barry
>> On Mar 24, 2008, at 10:07 PM, Matthew Knepley wrote:
>>> On Mon, Mar 24, 2008 at 9:50 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>>> On Mar 24, 2008, at 10:57 AM, Lisandro Dalcin wrote:
>>>>> Barry, things are still broken. I think that at some point we have
>>>>> to
>>>>> review the 'install:' target  more carefully.
>>>>> First, the 'sed' command i being called in a wrong way.
>>>>   This is not true; the sed is being called correctly. The problem
>>>> is that -i
>>>> is not a standard sed option and different systems gnu and freebsd
>>>> treat
>>>> it differently. freebsd requires a space between the -i and the
>>>> suffix;
>>>> gnu has no space; gnu also allows the use of -i to indicate no
>>>> backup
>>>> while freebsd expects -i ""
>>>>  Your patch works on POS gnu systems, but is broken on far superior
>>>> Apple MacOS X systems! :-)
>>>>   Matt you need to add a config/configure.py test to detect the
>>>> type of sed -i it is.
>>> I totally disagree. We should ditch all this crap, and just write
>>> nice, PORTABLE
>>> Python code. I will do it. I just need someone to explain what this
>>> sed is doing.
>>>  Matt
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
> -- Norbert Wiener
