petscvariables: hardwired build dir instead of install dir
Sat Mar 22 08:38:33 CDT 2008
On Mar 22, 2008, at 8:28 AM, Lisandro Dalcin wrote:
> Barry, I noticed that in the 'petscvariables' file, some of the config
> vars for external packages (XXX_INCLUDE and XXX_LIB) have hardwired
> the build dir as basepath, instead of the install dir given with
> --prefix. This smells bad, but I'm not sure. What do you think? I tend
> to think that every dir/file inside $PETSC_DIR should have its
> basepath defined in terms of
> "$PETSC_DIR/$PETSC_ARCH/innerdir[/filename.ext]".
    Lisandro,
      Specifically what packages?
      Do you mean that it lists, for example,
SUPERLU_DIST_LIB = -Wl,-rpath,/Users/bsmith/Src/petsc-dev/arch-icc-
superlu_dist/lib -L/Users/bsmith/Src/petsc-dev/arch-icc-superlu_dist/
lib -lsuperlu_dist_2.2
instead of
SUPERLU_DIST_LIB = -Wl,-rpath,$PETSC_DIR/arch-icc-superlu_dist/lib -L
$PETSC_DIR/arch-icc-superlu_dist/lib -lsuperlu_dist_2.2
or do you mean some config/PETSc/packages/*.py ignore the --prefix
option, which ones?
    Barry
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
