petscvariables: hardwired build dir instead of install dir
    Lisandro Dalcin
    dalcinl at gmail.com
    Sat Mar 22 08:28:50 CDT 2008
Barry, I noticed that in the 'petscvariables' file, some of the config
vars for external packages (XXX_INCLUDE and XXX_LIB) have hardwired
the build dir as basepath, instead of the install dir given with
--prefix. This smells bad, but I'm not sure. What do you think? I tend
to think that every dir/file inside $PETSC_DIR should have its
basepath defined in terms of
"$PETSC_DIR/$PETSC_ARCH/innerdir[/filename.ext]".
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
