petscvariables: hardwired build dir instead of install dir
Lisandro Dalcin dalcinl at gmail.com
Sat Mar 22 09:00:07 CDT 2008
On 3/22/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
>       Do you mean that it lists, for example,
>  SUPERLU_DIST_LIB = -Wl,-rpath,/Users/bsmith/Src/petsc-dev/arch-icc-
>  superlu_dist/lib -L/Users/bsmith/Src/petsc-dev/arch-icc-superlu_dist/
>  lib -lsuperlu_dist_2.2
>  instead of
>  SUPERLU_DIST_LIB = -Wl,-rpath,$PETSC_DIR/arch-icc-superlu_dist/lib -L
>  $PETSC_DIR/arch-icc-superlu_dist/lib -lsuperlu_dist_2.2
exactly that, as an example, I've just built petsc-dev, passing as
prefix the following '--prefix=/usr/local/petsc/2.3.3/linux-gnu' (yes,
I still want to have multiconfig installations of petsc in a central
location, so I add the PETSC_ARCH to the prefix)
But the 'petscvariables' file stills says, for example
ML_INCLUDE = -I. -I/usr/local/mpich2/1.0.6/include
-I/repos/hg/petsc/petsc-dev/linux-gnu/include
The last include dir is the directory were I've built PETSc. I would
love to see that include as -I${PETSC_DIR}/${PETSC_ARCH}/include. And
now, if external packages got installed in $PETSC_DIR/$PETSC_ARCH, we
perhaps could just put nothing, as that location is always taken into
accout for PETSc itself.
The real problem: if I remove the build dir, the 'petscvariables'
point to locations that no longer exists, This is dangerous. I already
had trouble in the past with the old 'bmake' based system. Is there a
chance to 'fix' this, or I'm missing something?
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
