changes to plapack usage in petsc-dev
Barry Smith
bsmith at mcs.anl.gov
Tue Mar 4 06:44:27 CST 2008
On Mar 3, 2008, at 11:37 PM, Yujie wrote:
> Dear Barry:
> Did you test them? I want to use this function. However, I am
> wondering whether there is some bugs in Petsc-dev.
There is always the possibility of bugs in PETSc (or any software),
if you have information about a
possible bug you have to send more than "is there some bugs", I cannot
use "is there some bugs" to track
down the problem. Please send full output on what goes wrong.
I ran our three plapack test problems src/mat/examples/tests
ex103.c ex107.c and ex115.c to test my
changes.
> In addition, is it easy to convert the version from 2.3.3-p8 to
> petsc-dev? thanks a lot.
The file src/docs/website/documentation/changes/dev.html shows the
differences in petsc-dev from
the last release. In general they are small and code that uses
petsc-2.3.3 can easily be changed to
use petsc-dev.
Barry
> Regards,
> Yujie
> On 3/4/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
> petsc-dev users,
> I have changed the way PLAPACK is used in petsc-dev. There is no
> longer
> a MATPLAPACK that needs to be set, rather so long as PETS was config/
> configure.py
> using --download-plapack all you need do is use the MATMPIDENSE
> matrices
> and PLAPACK will automatically be used for the solvers.
> Barry
> You should rm the externalpackages/plapack* routine before config/
> configure.py the latest
> Petsc-dev
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20080304/21f8b475/attachment.html>
