changes to plapack usage in petsc-dev
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Mar  4 10:54:57 CST 2008
   If your build failed. Try
1) do another hg pull; hg update
2) do another rm -rf externalpackages/PLA*
3) rm $PETSC_ARCH/conf/PLAPACK
    It should then work,
   Barry
On Mar 3, 2008, at 11:37 PM, Yujie wrote:
> Dear Barry:
> Did you test them? I want to use this function. However, I am
> wondering whether there is some bugs in Petsc-dev. In addition, is
> it easy to convert the version from 2.3.3-p8 to petsc-dev? thanks a
> lot.
> Regards,
> Yujie
> On 3/4/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    petsc-dev users,
>     I have changed the way PLAPACK is used in petsc-dev. There is no
> longer
> a MATPLAPACK that needs to be set, rather so long as PETS was config/
> configure.py
> using --download-plapack all you need do is use the MATMPIDENSE
> matrices
> and PLAPACK will automatically be used for the solvers.
>     Barry
> You should rm the externalpackages/plapack* routine before config/
> configure.py the latest
> Petsc-dev
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20080304/f4905196/attachment.html>
