changes to plapack usage in petsc-dev
    Yujie
    recrusader at gmail.com
    Mon Mar  3 23:37:13 CST 2008
Dear Barry:
Did you test them? I want to use this function. However, I am wondering
whether there is some bugs in Petsc-dev. In addition, is it easy to convert
the version from 2.3.3-p8 to petsc-dev? thanks a lot.
Yujie
On 3/4/08, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    petsc-dev users,
>     I have changed the way PLAPACK is used in petsc-dev. There is no
> longer
> a MATPLAPACK that needs to be set, rather so long as PETS was config/
> configure.py
> using --download-plapack all you need do is use the MATMPIDENSE matrices
> and PLAPACK will automatically be used for the solvers.
>     Barry
> You should rm the externalpackages/plapack* routine before config/
> configure.py the latest
> Petsc-dev
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20080304/976a6ac3/attachment.html>
