changes to plapack usage in petsc-dev
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Mar  3 21:28:59 CST 2008
   petsc-dev users,
    I have changed the way PLAPACK is used in petsc-dev. There is no
longer
a MATPLAPACK that needs to be set, rather so long as PETS was config/
configure.py
using --download-plapack all you need do is use the MATMPIDENSE matrices
and PLAPACK will automatically be used for the solvers.
    Barry
You should rm the externalpackages/plapack* routine before config/
configure.py the latest
Petsc-dev
