problem with PetscSynchronizedFPrintf (fwd)
Barry Smith
bsmith at mcs.anl.gov
Mon Jul 21 15:32:17 CDT 2008
Matt,
While you are at it could you please fix the buggy code in mprint.c?
make PETSC_DIR=/Users/bsmith/Src/petsc-dev-for-fixes PETSC_ARCH=arch-
icc-ifort
/Users/bsmith/Src/petsc-dev-for-fixes/arch-icc-ifort/bin/mpicc -o
mprint.o -c -wd1572 -Qoption,cpp,--extended_float_type -g -I/Users/
bsmith/Src/petsc-dev-for-fixes -I/Users/bsmith/Src/petsc-dev-for-fixes/
arch-icc-ifort/include -I/Users/bsmith/Src/petsc-dev-for-fixes/include
-I/usr/X11/include -I/Users/bsmith/Src/petsc-dev-for-fixes/arch-icc-
ifort/include -D__SDIR__='"src/sys/fileio/"' mprint.c
mprint.c(350): warning #592: variable "fullLength" is used before its
value is set
while(fullLength >= next->size) {
On Jul 21, 2008, at 3:30 PM, Matthew Knepley wrote:
> Pushed a fix. I missed the Viewer when I corrected the raw call.
> That should
> not be separate code.
> Matt
> On Mon, Jul 21, 2008 at 2:54 PM, Satish Balay <balay at mcs.anl.gov>
> wrote:
>> Matt - Perhaps ex7 is a different Problem. But it does crash for me.
>> And I noticed the following code:
>> ierr = PetscNew(struct _PrintfQueue,&next);CHKERRQ(ierr);
>> if (queue) {queue->next = next; queue = next;}
>> else {queuebase = queue = next;}
>> queuelength++;
>> string = next->string;
>> ierr = PetscMemzero(string,QUEUESTRINGSIZE);CHKERRQ(ierr);
>> i.e 'next' is allocated - here is no malloc for 'next->string'. But
>> its being zeroed in PetscMemzero() - hence the crash with ex7 for me.
>> Satish
>> asterix:/home/balay/spetsc/src/dm/ao/examples/tests>mpiexec -n 2 ./
>> ex7
>> Number of elements in ordering 10
>> PETSc->App App->PETSc
>> 0 0 0 0
>> 1 5 1 2
>> 2 1 2 4
>> 3 6 3 6
>> 4 2 4 8
>> 5 7 5 1
>> 6 3 6 3
>> 7 8 7 5
>> 8 4 8 7
>> 9 9 9 9
>> [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Null argument, when expecting valid pointer!
>> [1]PETSC ERROR: Trying to zero at a null pointer!
>> [1]PETSC ERROR:
>> [1]PETSC ERROR: Petsc Development Version 2.3.3, Patch 13, unknown
>> HG revision: unknown
>> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [1]PETSC ERROR: See docs/index.html for manual pages.
>> [1]PETSC ERROR:
>> [1]PETSC ERROR: ./ex7 on a asterix64 named asterix by balay Mon Jul
>> 21 14:51:02 2008
>> [1]PETSC ERROR: Libraries linked from /home/balay/spetsc/lib
>> [1]PETSC ERROR: Configure run at Mon Jul 21 10:38:52 2008
>> [1]PETSC ERROR: Configure options --with-mpi-dir=/home/balay/soft/
>> linux64/mpich2-1.0.7 --with-shared=1 PETSC_ARCH=asterix64
>> [1]PETSC ERROR: ----------------------------[0] Number of indices
>> in (stride) set 5
>> [0] 0 0
>> [0] 1 2
>> [0] 2 4
>> [0] 3 6
>> [0] 4 8
>> [1]PETSC ERROR: PetscMemzero() line 189 in src/sys/utils/memc.c
>> [1]PETSC ERROR: PetscViewerASCIISynchronizedPrintf() line 859 in
>> src/sys/viewer/impls/ascii/filev.c
>> [1]PETSC ERROR: ISView_Stride() line 231 in src/vec/is/impls/stride/
>> stride.c
>> [1]PETSC ERROR: ISView() line 398 in src/vec/is/interface/index.c
>> [1]PETSC ERROR: main() line 31 in src/dm/ao/examples/tests/ex7.c
>> application called MPI_Abort(MPI_COMM_WORLD, 85) - process
>> 1[cli_1]: aborting job:
>> application called MPI_Abort(MPI_COMM_WORLD, 85) - process 1
>> [0]0:Return code = 0, signaled with Interrupt
>> [0]1:Return code = 85
>> On Mon, 21 Jul 2008, Matthew Knepley wrote:
>>> I made this change because synchronized printing was cutting off my
>>> stuff. Now the queue is dynamically allocated so it can accomodate
>>> any size string.
>>> I tried ex7 and it runs fine for me, even under valgrind.
>>> Shi, can you reproduce this with a Sieve example?
>>> Matt
>>> On Mon, Jul 21, 2008 at 2:37 PM, Satish Balay <balay at mcs.anl.gov>
>>> wrote:
>>>> Looks like this could be related to changeset 9e3fbe04a926
>>>> --> mprint.h <--
>>>> - char string[QUEUESTRINGSIZE];
>>>> + char *string;
>>>> So now strings needs to use malloc()/free()?
>>>> Matt - you can reproduce this issue with dm/ao/examples/tests/ex7.c
>>>> Satish
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
