problem with PetscSynchronizedFPrintf (fwd)
    Matthew Knepley
    knepley at gmail.com
    Mon Jul 21 15:30:31 CDT 2008
Pushed a fix. I missed the Viewer when I corrected the raw call. That should
not be separate code.
  Matt
On Mon, Jul 21, 2008 at 2:54 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Matt - Perhaps ex7 is a different Problem. But it does crash for me.
> And I noticed the following code:
>    ierr = PetscNew(struct _PrintfQueue,&next);CHKERRQ(ierr);
>    if (queue) {queue->next = next; queue = next;}
>    else       {queuebase   = queue = next;}
>    queuelength++;
>    string = next->string;
>    ierr = PetscMemzero(string,QUEUESTRINGSIZE);CHKERRQ(ierr);
> i.e 'next' is allocated - here is no malloc for 'next->string'. But
> its being zeroed in PetscMemzero() - hence the crash with ex7 for me.
> Satish
> asterix:/home/balay/spetsc/src/dm/ao/examples/tests>mpiexec -n 2 ./ex7
> Number of elements in ordering 10
> PETSc->App  App->PETSc
>  0    0      0    0
>  1    5      1    2
>  2    1      2    4
>  3    6      3    6
>  4    2      4    8
>  5    7      5    1
>  6    3      6    3
>  7    8      7    5
>  8    4      8    7
>  9    9      9    9
> [1]PETSC ERROR: --------------------- Error Message ------------------------------------
> [1]PETSC ERROR: Null argument, when expecting valid pointer!
> [1]PETSC ERROR: Trying to zero at a null pointer!
> [1]PETSC ERROR: ------------------------------------------------------------------------
> [1]PETSC ERROR: Petsc Development Version 2.3.3, Patch 13, unknown HG revision: unknown
> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [1]PETSC ERROR: See docs/index.html for manual pages.
> [1]PETSC ERROR: ./ex7 on a asterix64 named asterix by balay Mon Jul 21 14:51:02 2008
> [1]PETSC ERROR: Libraries linked from /home/balay/spetsc/lib
> [1]PETSC ERROR: Configure run at Mon Jul 21 10:38:52 2008
> [1]PETSC ERROR: Configure options --with-mpi-dir=/home/balay/soft/linux64/mpich2-1.0.7 --with-shared=1 PETSC_ARCH=asterix64
> [1]PETSC ERROR: ----------------------------[0] Number of indices in (stride) set 5
> [0] 0 0
> [0] 1 2
> [0] 2 4
> [0] 3 6
> [0] 4 8
> [1]PETSC ERROR: PetscMemzero() line 189 in src/sys/utils/memc.c
> [1]PETSC ERROR: PetscViewerASCIISynchronizedPrintf() line 859 in src/sys/viewer/impls/ascii/filev.c
> [1]PETSC ERROR: ISView_Stride() line 231 in src/vec/is/impls/stride/stride.c
> [1]PETSC ERROR: ISView() line 398 in src/vec/is/interface/index.c
> [1]PETSC ERROR: main() line 31 in src/dm/ao/examples/tests/ex7.c
> application called MPI_Abort(MPI_COMM_WORLD, 85) - process 1[cli_1]: aborting job:
> [0]0:Return code = 0, signaled with Interrupt
> [0]1:Return code = 85
> On Mon, 21 Jul 2008, Matthew Knepley wrote:
>> I made this change because synchronized printing was cutting off my
>> stuff. Now the queue is dynamically allocated so it can accomodate
>> any size string.
>> I tried ex7 and it runs fine for me, even under valgrind.
>> Shi, can you reproduce this with a Sieve example?
>>   Matt
>> On Mon, Jul 21, 2008 at 2:37 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> > Looks like this could be related to changeset 9e3fbe04a926
>> > --> mprint.h <--
>> > -  char        string[QUEUESTRINGSIZE];
>> > +  char       *string;
>> > So now strings needs to use malloc()/free()?
>> > Matt - you can reproduce this issue with dm/ao/examples/tests/ex7.c
>> > Satish
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
