problem with PetscSynchronizedFPrintf (fwd)
    Matthew Knepley
    knepley at gmail.com
    Mon Jul 21 15:35:53 CDT 2008
Fixed.
  Matt
On Mon, Jul 21, 2008 at 3:32 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Matt,
>  While you are at it could you please fix the buggy code in mprint.c?
> make PETSC_DIR=/Users/bsmith/Src/petsc-dev-for-fixes
> PETSC_ARCH=arch-icc-ifort
> /Users/bsmith/Src/petsc-dev-for-fixes/arch-icc-ifort/bin/mpicc -o mprint.o
> -c -wd1572 -Qoption,cpp,--extended_float_type -g
> -I/Users/bsmith/Src/petsc-dev-for-fixes
> -I/Users/bsmith/Src/petsc-dev-for-fixes/arch-icc-ifort/include
> -I/Users/bsmith/Src/petsc-dev-for-fixes/include -I/usr/X11/include
>  -D__SDIR__='"src/sys/fileio/"'  mprint.c
> mprint.c(350): warning #592: variable "fullLength" is used before its value
> is set
>      while(fullLength >= next->size) {
> On Jul 21, 2008, at 3:30 PM, Matthew Knepley wrote:
>> Pushed a fix. I missed the Viewer when I corrected the raw call. That
>> should
>> not be separate code.
>>  Matt
>> On Mon, Jul 21, 2008 at 2:54 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> Matt - Perhaps ex7 is a different Problem. But it does crash for me.
>>> And I noticed the following code:
>>>  ierr = PetscNew(struct _PrintfQueue,&next);CHKERRQ(ierr);
>>>  if (queue) {queue->next = next; queue = next;}
>>>  else       {queuebase   = queue = next;}
>>>  queuelength++;
>>>  string = next->string;
>>>  ierr = PetscMemzero(string,QUEUESTRINGSIZE);CHKERRQ(ierr);
>>> i.e 'next' is allocated - here is no malloc for 'next->string'. But
>>> its being zeroed in PetscMemzero() - hence the crash with ex7 for me.
>>> Satish
>>> asterix:/home/balay/spetsc/src/dm/ao/examples/tests>mpiexec -n 2 ./ex7
>>> Number of elements in ordering 10
>>> PETSc->App  App->PETSc
>>> 0    0      0    0
>>> 1    5      1    2
>>> 2    1      2    4
>>> 3    6      3    6
>>> 4    2      4    8
>>> 5    7      5    1
>>> 6    3      6    3
>>> 7    8      7    5
>>> 8    4      8    7
>>> 9    9      9    9
>>> [1]PETSC ERROR: --------------------- Error Message
>>> [1]PETSC ERROR: Null argument, when expecting valid pointer!
>>> [1]PETSC ERROR: Trying to zero at a null pointer!
>>> [1]PETSC ERROR:
>>> [1]PETSC ERROR: Petsc Development Version 2.3.3, Patch 13, unknown HG
>>> revision: unknown
>>> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> [1]PETSC ERROR: See docs/index.html for manual pages.
>>> [1]PETSC ERROR:
>>> [1]PETSC ERROR: ./ex7 on a asterix64 named asterix by balay Mon Jul 21
>>> 14:51:02 2008
>>> [1]PETSC ERROR: Libraries linked from /home/balay/spetsc/lib
>>> [1]PETSC ERROR: Configure run at Mon Jul 21 10:38:52 2008
>>> [1]PETSC ERROR: Configure options
>>> --with-mpi-dir=/home/balay/soft/linux64/mpich2-1.0.7 --with-shared=1
>>> PETSC_ARCH=asterix64
>>> [1]PETSC ERROR: ----------------------------[0] Number of indices in
>>> (stride) set 5
>>> [0] 0 0
>>> [0] 1 2
>>> [0] 2 4
>>> [0] 3 6
>>> [0] 4 8
>>> [1]PETSC ERROR: PetscMemzero() line 189 in src/sys/utils/memc.c
>>> [1]PETSC ERROR: PetscViewerASCIISynchronizedPrintf() line 859 in
>>> src/sys/viewer/impls/ascii/filev.c
>>> [1]PETSC ERROR: ISView_Stride() line 231 in
>>> src/vec/is/impls/stride/stride.c
>>> [1]PETSC ERROR: ISView() line 398 in src/vec/is/interface/index.c
>>> [1]PETSC ERROR: main() line 31 in src/dm/ao/examples/tests/ex7.c
>>> application called MPI_Abort(MPI_COMM_WORLD, 85) - process 1[cli_1]:
>>> aborting job:
>>> [0]0:Return code = 0, signaled with Interrupt
>>> [0]1:Return code = 85
>>> On Mon, 21 Jul 2008, Matthew Knepley wrote:
>>>> I made this change because synchronized printing was cutting off my
>>>> stuff. Now the queue is dynamically allocated so it can accomodate
>>>> any size string.
>>>> I tried ex7 and it runs fine for me, even under valgrind.
>>>> Shi, can you reproduce this with a Sieve example?
>>>>  Matt
>>>> On Mon, Jul 21, 2008 at 2:37 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> Looks like this could be related to changeset 9e3fbe04a926
>>>>> --> mprint.h <--
>>>>> -  char        string[QUEUESTRINGSIZE];
>>>>> +  char       *string;
>>>>> So now strings needs to use malloc()/free()?
>>>>> Matt - you can reproduce this issue with dm/ao/examples/tests/ex7.c
>>>>> Satish
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
-- Norbert Wiener
