[PETSC #18705] PETSc and Cygwin License (POSIX layer)
Barry Smith
bsmith at mcs.anl.gov
Thu Dec 4 12:42:19 CST 2008
Make is NOT the problem! (It is just one of several)
Config/configure.py uses the SHELL constantly for basically
everything. Try running config/configure.py
under Windows without using cygwin.
I hate the term "toolchain"
Barry
On Dec 4, 2008, at 12:04 PM, Matthew Knepley wrote:
> I for one think it should be possible to remove 'make' from the
> toolchain, leaving us with only win32fe, which we distribute. Thus
> I think we could abandon cygwin once and for all. I would even be
> willing to write a \emph{make clone} to accomplish this, even though
> I am a committed enemy of make (which once TP'ed my house).
> Matt
> ---------- Forwarded message ----------
> From: Barry Smith <bsmith at mcs.anl.gov>
> Date: Thu, Dec 4, 2008 at 12:00 PM
> Subject: Re: [PETSC #18705] PETSc and Cygwin License (POSIX layer)
> To: Stefan Benkler <benkler at itis.ethz.ch>
> Cc: petsc-maint at mcs.anl.gov
> Stefan,
> Here is my understanding of the situation.
> Conjecture: You CAN use an open source compiler (GNU) to compile
> proprietary code and then sell
> the binaries without making the proprietary code GNU licensed so
> long as you just use the
> GNU compilers out of the box and don't change their source code and
> don't include the compliers
> libraries in your binaries.
> IF this is true then you are safe, the Cygwin environment is only
> used by PETSc to have
> a system to compile PETSc. None of it is included in the binaries
> generated.
> On the other hand, if my initial conjecture is wrong, then there
> could be a problem.
> Barry
> We've tried over the years to use Windows "posix" environments to
> develop a build system
> for PETSc so we don't need cygwin to build PETSc. Unfortunately
> their stuff is so "un-unix"
> like that it just wasn't practical and using developers studio to
> build PETSc directly is
> possible but requires some how getting all the PETSc source properly
> into developers studio
> and as far as I know the only way to do this is manually through the
> gui which is very painful;
> plus if we change something in the Unix build side later we'd need
> to change it manually
> on the developers studio side.
> If the situation has changed and Windows does provide a reasonable
> way to build large
> unix codes I'd love to hear about it and use it. We hate cygwin but
> feel with have no other
> reasonable option.
> On Dec 4, 2008, at 3:33 AM, Stefan Benkler wrote:
> Dear PETSc developers
> Since a while, I successfully use your fantastic library on Windows.
> Thank you very much!
> Lately, I had a discussion about the involved copyrights/licenses
> with a colleague. The main point was if PETSc requires the POSIX
> layer of cygwin on Windows (and therefore would need to fulfill
> cygwin's GPL license).
> My standpoint was that cygwin is just used to configure and build
> the library, but only native Windows libraries (using MS or Intel's
> Windows compiler, MKL) are finally linked to the PETSc libs.
> However, I have difficulties to proof this claim, which is the
> reason for this email.
> Please comment/clarify the licensing on a Windows system.
> Thanks a lot for your informations.
> Best regards
> Stefan Benkler
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
