some problems with 'make install'
    Satish Balay
    balay at mcs.anl.gov
    Tue Dec  2 13:31:02 CST 2008
On Mon, 1 Dec 2008, Lisandro Dalcin wrote:
> I'm testing configure passing '--prefix=....', and after building, I do
> $ su -c 'make install'
> But then, some files ('configure.log', 'RDict.db') are left with
> 'root:root' owner and group. If you want to build/rebuild again, this
> fails bad.
> And you know, using 'sudo' is not always a chance, as depending on
> 'sudo' configuration, it does not preserve the environment.
I don't see configure.log - but I see build.log and default.log. These
should not cause conflict - but RDict.db does.
Matt would have to check this issue. Ideally most of these files
should not be created during 'make install'
As a hack - I can add os.remove('RDict.db') in config/installer.py
Satish
