some problems with 'make install'
    Lisandro Dalcin
    dalcinl at gmail.com
    Mon Dec  1 15:07:55 CST 2008
I'm testing configure passing '--prefix=....', and after building, I do
$ su -c 'make install'
But then, some files ('configure.log', 'RDict.db') are left with
'root:root' owner and group. If you want to build/rebuild again, this
fails bad.
And you know, using 'sudo' is not always a chance, as depending on
'sudo' configuration, it does not preserve the environment.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
