some problems with 'make install'
Matthew Knepley
knepley at gmail.com
Tue Dec 2 13:40:45 CST 2008
On Tue, Dec 2, 2008 at 1:31 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 1 Dec 2008, Lisandro Dalcin wrote:
> > I'm testing configure passing '--prefix=....', and after building, I do
> > $ su -c 'make install'
> > But then, some files ('configure.log', 'RDict.db') are left with
> > 'root:root' owner and group. If you want to build/rebuild again, this
> > fails bad.
> > And you know, using 'sudo' is not always a chance, as depending on
> > 'sudo' configuration, it does not preserve the environment.
> I don't see configure.log - but I see build.log and default.log. These
> should not cause conflict - but RDict.db does.
> Matt would have to check this issue. Ideally most of these files
> should not be created during 'make install'
> As a hack - I can add os.remove('RDict.db') in config/installer.py
I am for this.
Matt
> Satish
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20081202/d0e1aeec/attachment.html>
