renaming in PC
Lisandro Dalcin
dalcinl at gmail.com
Tue Oct 9 15:32:27 CDT 2007
Good point...
So we should rename
PetscErrorCode PCHasApplyTranspose(PC,PetscTruth*)
to
PetscErrorCode PCApplyTransposeExists(PC,PetscTruth*)
On 10/9/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> HasApply is more grammatical. But I like having the naming
> follow the pattern of
> PCXXYY
> PCXXYYzz
> PCXXYYww
> rather than PCzzXXYY, or PCwwXXYY etc.
> That is as much of the strings should start the same way for
> related routines. Hence PCApplyRichardsonExists() is
> near PCApplyRichardson() while PCHasApplyRichardson()
> is kilometers away.
> Barry
> Hence we have
> KSPMonitor()
> KSPMonitorSet()
> KSPMonitorCancel()
> KSPMonitorSingularValue()
> KSPMonitorDefault()
> I realize the KSPMonitorSet() instead of KSPSetMonitor() is non-standard but
> that doesn't mean it is wrong :-).
> Essentially when you sort the function names, I'd like the related ones
> together.
> On Tue, 9 Oct 2007, Lisandro Dalcin wrote:
> > Which form should be the preferred one? I'm inclined for the fist...
> > PetscErrorCode PCApplyRichardsonExists(PC,PetscTruth*)
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
