renaming in PC
Barry Smith
bsmith at mcs.anl.gov
Tue Oct 9 15:36:22 CDT 2007
Well yes. There are probably others as well :-(
Barry
On Tue, 9 Oct 2007, Lisandro Dalcin wrote:
> Good point...
> So we should rename
> PetscErrorCode PCHasApplyTranspose(PC,PetscTruth*)
> to
> PetscErrorCode PCApplyTransposeExists(PC,PetscTruth*)
> On 10/9/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > HasApply is more grammatical. But I like having the naming
> > follow the pattern of
> > PCXXYY
> > PCXXYYzz
> > PCXXYYww
> > rather than PCzzXXYY, or PCwwXXYY etc.
> > That is as much of the strings should start the same way for
> > related routines. Hence PCApplyRichardsonExists() is
> > near PCApplyRichardson() while PCHasApplyRichardson()
> > is kilometers away.
> > Barry
> > Hence we have
> > KSPMonitor()
> > KSPMonitorSet()
> > KSPMonitorCancel()
> > KSPMonitorSingularValue()
> > KSPMonitorDefault()
> > I realize the KSPMonitorSet() instead of KSPSetMonitor() is non-standard but
> > that doesn't mean it is wrong :-).
> > Essentially when you sort the function names, I'd like the related ones
> > together.
> > > Which form should be the preferred one? I'm inclined for the fist...
> > > PetscErrorCode PCApplyRichardsonExists(PC,PetscTruth*)
