renaming in PC
Barry Smith
bsmith at mcs.anl.gov
Tue Oct 9 15:22:54 CDT 2007
HasApply is more grammatical. But I like having the naming
follow the pattern of
PCXXYY
PCXXYYzz
PCXXYYww
rather than PCzzXXYY, or PCwwXXYY etc.
That is as much of the strings should start the same way for
related routines. Hence PCApplyRichardsonExists() is
near PCApplyRichardson() while PCHasApplyRichardson()
is kilometers away.
Barry
Hence we have
KSPMonitor()
KSPMonitorSet()
KSPMonitorCancel()
KSPMonitorSingularValue()
KSPMonitorDefault()
I realize the KSPMonitorSet() instead of KSPSetMonitor() is non-standard but
that doesn't mean it is wrong :-).
Essentially when you sort the function names, I'd like the related ones
together.
On Tue, 9 Oct 2007, Lisandro Dalcin wrote:
> Which form should be the preferred one? I'm inclined for the fist...
> PetscErrorCode PCHasApplyTranspose(PC,PetscTruth*)
> PetscErrorCode PCApplyRichardsonExists(PC,PetscTruth*)
