more comments about new build system
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Jun 12 17:03:24 CDT 2007
  Ok, so far we have
  prefix/conf
  prefix/lib/conf        (or petscconf or petsc)
  prefix/etc/conf        (or petscconf or petsc)
  prefix/share/conf     (or petscconf or petsc
  Barry
On Tue, 12 Jun 2007, Lisandro Dalcin wrote:
> Barry,
> What about putting 'conf' inside '$PETSC_ARCH/lib'
> In the build directory, arch specific 'conf' dir will be in
> $PESC_DIR/$PETSC_ARCH/lib/conf
> In the install directory, it will be
> '$PETSC_PREFIX/lib/conf'
> In such a case, perhaps you can use 'petsc' instead of 'conf'. I am
> taking here python as example, in my box I have under '/usr/lib'
> /usr/lib/libpython2.4.so -> libpython2.4.so.1.0
> /usr/lib/libpython2.4.so.1.0
> /usr/lib/python2.4
> And also I have under '/usr/include'
> /usr/include/python2.4
> This is great because the standard 'include' dir is not populated with
> many headers, but for petsc this would complicate things.
> On 6/11/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >     Good point. etc was also suggested. Adding the petsc is
> > kind of ugly with the non-installed version, for example
> > petsc-dev/$PETSC_ARCH/shared/petsc/petscrules
> > instead of
> > petsc-dev/$PETSC_ARCH/shared/petscrules
> >   These things are still up in the air and will be adjusted
> > as good ideas come in.
> >    Barry
> > On Mon, 11 Jun 2007, Lisandro Dalcin wrote:
> > > If one of the goals of the new build system is to be more symmetric
> > > with the GNU model, in order to make life easier for packagers, so I
> > > think the '$PETSC_PREFIX/conf' location should be renamed, perhaps to
> > > '$PETSC_PREFIX/share/petsc'. I believe 'conf' is not a 'standard'
> > > location.
