more comments about new build system
Lisandro Dalcin dalcinl at gmail.com
Tue Jun 12 10:18:57 CDT 2007
Barry,
What about putting 'conf' inside '$PETSC_ARCH/lib'
In the build directory, arch specific 'conf' dir will be in
$PESC_DIR/$PETSC_ARCH/lib/conf
In the install directory, it will be
'$PETSC_PREFIX/lib/conf'
In such a case, perhaps you can use 'petsc' instead of 'conf'. I am
taking here python as example, in my box I have under '/usr/lib'
/usr/lib/libpython2.4.so -> libpython2.4.so.1.0
/usr/lib/libpython2.4.so.1.0
/usr/lib/python2.4
And also I have under '/usr/include'
/usr/include/python2.4
This is great because the standard 'include' dir is not populated with
many headers, but for petsc this would complicate things.
On 6/11/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
>     Good point. etc was also suggested. Adding the petsc is
> kind of ugly with the non-installed version, for example
> petsc-dev/$PETSC_ARCH/shared/petsc/petscrules
> instead of
> petsc-dev/$PETSC_ARCH/shared/petscrules
>   These things are still up in the air and will be adjusted
> as good ideas come in.
>    Barry
> On Mon, 11 Jun 2007, Lisandro Dalcin wrote:
> > If one of the goals of the new build system is to be more symmetric
> > with the GNU model, in order to make life easier for packagers, so I
> > think the '$PETSC_PREFIX/conf' location should be renamed, perhaps to
> > '$PETSC_PREFIX/share/petsc'. I believe 'conf' is not a 'standard'
> > location.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
