more comments about new build system
Lisandro Dalcin
dalcinl at gmail.com
Tue Jun 12 18:30:16 CDT 2007
No, No, Barry...
Sorry, I was not clear enough. I was thinking in having
* In an 'install' directory
prefix/bin (generated executables)
prefix/include (all headers) [ Perhaps prefix/include/petsc? ]
prefix/lib ( all petsc *.a and *.so libs)
prefix/lib/petsc (all configuration, common and arch-specific)
So if 'prefix' is '/usr' you do not generate a non standard
'/usr/conf' directory.
* In an 'build' directory
$PETSC_DIR/bin
$PETSC_DIR/include (common headers)
$PETSC_DIR/conf (common config)
$PETSC_DIR/$PETSC_ARCH/bin (generated executables)
$PETSC_DIR/$PETSC_ARCH/include (arch-specific headers)
$PETSC_DIR/$PETSC_ARCH/lib (*.a and *.so libs)
$PETSC_DIR/$PETSC_ARCH/lib/petsc (arch-specific config)
I think this approach retains some degree of symmetry between 'prefix'
and $PETSC_DIR, and uses a more standard layout in 'prefix'
What do you think?
On 6/12/07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Ok, so far we have
> prefix/conf
> prefix/lib/conf (or petscconf or petsc)
> prefix/etc/conf (or petscconf or petsc)
> prefix/share/conf (or petscconf or petsc
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
