changes to PETSc-dev bmake system and library locations
Lisandro Dalcin
dalcinl at gmail.com
Mon Jun 11 13:43:15 CDT 2007
I think 'conf/variables' needs a bit more of work. I am not sure about
what to do, the problem is here:
PETSC_LIB_DIR = ${PETSC_DIR}/${PETSC_ARCH}/lib
PETSC_INCLUDE = -I${PETSC_DIR}
-I${PETSC_DIR}/${PETSC_ARCH}/include -I${PETSC_DIR}/include \
${PACKAGES_INCLUDES} ${TAU_DEFS}
${TAU_INCLUDE} ${PETSC_BLASLAPACK_FLAGS}
As you can see, there are references to $PESC_ARCH. So there are two
potential problems using a 'install' version:
1.- If $PETSC_ARCH is not defined, some paths are of the form
'/usr/local/petsc//lib'. Not sure is the double '//' could be
problematic.
2.- If $PETSC_ARCH is defined somewhere (user makefiles or even
environment), bad paths will be generated, and ${PETSC_LIB_DIR} is
definitely broken.
Is all this OK? Or my hg pull + hg update failed?
On 6/11/07, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 6/11/07, Satish Balay <balay at mcs.anl.gov> wrote:
> > I should add that one motivation to support gnu/autoconf? 'make
> > insall' model as closly as possible - is to make it easy for
> > 'packagers' [deb,rpm etc..] to package PETSc
> OK, this make sense... I'll try this when I have some free time, I've
> been playing a bit generating rpm's for Fedora.
> [atleast the default
> > config - whatever that means] and make it available for their
> > respective distributions. Currently we only have only debian/freebsd
> > packages - and nothing more.
> > And I'm hoping that these packagers have their own models for
> > installing multiple configs [via different prefix], so potentially
> > multiple variants of PETSc config can be packaged [if they chose to do
> > it].
> > However I think the requirement of 'PETSC_DIR' might still be a minor
> > hurdle for this mode. [the alternative would be providing compiler
> > wrappers but thats a different discussion]
> > Satish
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
Lisandro Dalcín
