changes to PETSc-dev bmake system and library locations
Lisandro Dalcin dalcinl at gmail.com
Mon Jun 11 10:30:43 CDT 2007
On 6/11/07, Satish Balay <balay at mcs.anl.gov> wrote:
> I should add that one motivation to support gnu/autoconf? 'make
> insall' model as closly as possible - is to make it easy for
> 'packagers' [deb,rpm etc..] to package PETSc
OK, this make sense... I'll try this when I have some free time, I've
been playing a bit generating rpm's for Fedora.
[atleast the default
> config - whatever that means] and make it available for their
> respective distributions. Currently we only have only debian/freebsd
> packages - and nothing more.
> And I'm hoping that these packagers have their own models for
> installing multiple configs [via different prefix], so potentially
> multiple variants of PETSc config can be packaged [if they chose to do
> it].
> However I think the requirement of 'PETSC_DIR' might still be a minor
> hurdle for this mode. [the alternative would be providing compiler
> wrappers but thats a different discussion]
> Satish
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
