configure.py script
Matthew Knepley
knepley at gmail.com
Tue Jul 17 07:38:07 CDT 2007
We do generate makefiles, just not all of them. Automake is an unreadable,
inpenetrable mess that should never be used by anyone. Thus, we don't use it.
Matt
On 7/17/07, Sumit Vaidya <sumit_vaidya at persistent.co.in> wrote:
> Hi,
> I have downloaded the version 2.3.3-p3.
> There is one file under "config" folder viz "configure.py". I am building
> the library on Red Hat Linux 9.
> I saw some makefiles already there in the downloaded package.
> Then what is the use of "configure.py" script? I have no idea about python
> code, But I redirected the output of configure and came to know it is
> testing some folders.
> As per my knowledge, configure script is used to generate makefiles.
> What is the use of configure script in PETSc 2.3.3-p3 version?
> Waiting for your reply,
> Sumit
> DISCLAIMER ========== This e-mail may contain privileged and confidential
> information which is the property of Persistent Systems Pvt. Ltd. It is
> intended only for the use of the individual or entity to which it is
> addressed. If you are not the intended recipient, you are not authorized to
> read, retain, copy, print, distribute or use this message. If you have
> received this communication in error, please notify the sender and delete
> all copies of this message. Persistent Systems Pvt. Ltd. does not accept any
> liability for virus infected mails.
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
