configure.py script
    Sumit Vaidya
    sumit_vaidya at persistent.co.in
    Thu Jul 19 00:23:32 CDT 2007
I configured PETSc 2.3.3-p3 on Red Hat Linux.
I did not see any new makefiles generated. I came to know about this after
checking the time and date of the makefiles present in the all the
subfolders.
Do temporary makefiles get generated? I took the log of configure script
also. It is doing some testing.
Can you tell me what testing is it?
Waiting for your reply,
Sumit
We do generate makefiles, just not all of them. Automake is an unreadable,
inpenetrable mess that should never be used by anyone. Thus, we don't use
it.
     Matt
On 7/17/07, Sumit Vaidya <sumit_vaidya at persistent.co.in> wrote:
> Hi,
> I have downloaded the version 2.3.3-p3.
> There is one file under "config" folder viz "configure.py". I am building
> the library on Red Hat Linux 9.
> I saw some makefiles already there in the downloaded package.
> Then what is the use of "configure.py" script? I have no idea about python
> code, But I redirected the output of configure and came to know it is
> testing some folders.
> As per my knowledge, configure script is used to generate makefiles.
> What is the use of configure script in PETSc 2.3.3-p3 version?
> Sumit
DISCLAIMER
This e-mail may contain privileged and confidential information which is the property of Persistent Systems Pvt. Ltd. It is intended only for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you are not authorized to read, retain, copy, print, distribute or use this message. If you have received this communication in error, please notify the sender and delete all copies of this message. Persistent Systems Pvt. Ltd. does not accept any liability for virus infected mails.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20070719/1e7d678b/attachment.html>
