configure.py script
Sumit Vaidya
sumit_vaidya at persistent.co.in
Tue Jul 17 06:00:11 CDT 2007
I have downloaded the version 2.3.3-p3.
There is one file under "config" folder viz "configure.py". I am building
the library on Red Hat Linux 9.
I saw some makefiles already there in the downloaded package.
Then what is the use of "configure.py" script? I have no idea about python
code, But I redirected the output of configure and came to know it is
testing some folders.
As per my knowledge, configure script is used to generate makefiles.
What is the use of configure script in PETSc 2.3.3-p3 version?
Waiting for your reply,
Sumit
DISCLAIMER
This e-mail may contain privileged and confidential information which is the property of Persistent Systems Pvt. Ltd. It is intended only for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you are not authorized to read, retain, copy, print, distribute or use this message. If you have received this communication in error, please notify the sender and delete all copies of this message. Persistent Systems Pvt. Ltd. does not accept any liability for virus infected mails.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20070717/368420d2/attachment.html>
