Windows version of PETSc
Aron Ahmadia
aja2111 at columbia.edu
Fri Jul 13 09:18:09 CDT 2007
Hi Sumit,
I've posted this message to petsc-users, which is the right mailing
list for this sort of question.
You want to head to the official PETSc page if you'd like to download
the source:
http://www-unix.mcs.anl.gov/petsc/petsc-2/download/index.html
The installation instructions are also located there.
Good luck,
~Aron
On 6/13/07, Sumit Vaidya <sumit_vaidya at persistent.co.in> wrote:
> Hi,
> These are the machines supported by PETSc.
> http://www.caspur.it/risorse/softappl/doc/petsc_docs/machines.html
> From this, I came to know that PETSc is already available for Windows with
> 32-bit processor.
> Where can I get this software version of PETSc for windows?
> Waiting for your reply,
> Sumit
> DISCLAIMER ========== This e-mail may contain privileged and confidential
> information which is the property of Persistent Systems Pvt. Ltd. It is
> intended only for the use of the individual or entity to which it is
> addressed. If you are not the intended recipient, you are not authorized to
> read, retain, copy, print, distribute or use this message. If you have
> received this communication in error, please notify the sender and delete
> all copies of this message. Persistent Systems Pvt. Ltd. does not accept any
> liability for virus infected mails.
